  • 1.  Mobility Conductor in AWS or Azure
    Posted Feb 07, 2022 08:38 AM
    Hello all,
    Is running MC in AWS or Azure a supported design?
    Jason
  • 2.  RE: Mobility Conductor in AWS or Azure
    Posted Feb 07, 2022 01:32 PM
    No it is not.
    Seth Fiermonti
  • 3.  RE: Mobility Conductor in AWS or Azure
    Posted Feb 08, 2022 04:18 AM
    Thanks for the reply. I have read the ClearPass is supported in Azure, now i'm trying to find out if AirWave is supported in Azure.
    Jason
  • 4.  RE: Mobility Conductor in AWS or Azure
    Posted Feb 08, 2022 09:18 AM
    No it is not. Running anything that does SNMP, syslog, traps, etc... from the cloud is never a good idea
    Seth Fiermonti
