Mobility Conductor isnt showing APs in dashboard when MDs are clustered
This thread has been viewed 41 times
  • 1.  Mobility Conductor isnt showing APs in dashboard when MDs are clustered
    Posted Feb 02, 2022 09:16 AM
    Hi guys,
    I have an issue with the mobility conductor and 2 controllers which are clustered. Version is 8.7.1.7 on all of them.
    I can see the 2 controllers in the dashboard and the clustering works, L2 cluster up, vrrp up... I see active and standby AAC/UAC when connecting APs and users. I also see my APs when I go into configuration view and I can provision them . But I cannot see any AP/user connected on the dashboard. When I log into the controllers themself, I see either AP or users connected, depending which one is the active. Strangly I cant even see a the cluster in the dashboard, but when I go into the configuration > maintenance there it shows me the cluster...
    So actually "everything" works but nothing shows up...
    Is there anything I am missing?
    Best regards
    Raffael Hotz
  • 2.  RE: Mobility Conductor isnt showing APs in dashboard when MDs are clustered
    MVP EXPERT
    Posted Feb 03, 2022 06:43 AM
    We had the exact same issue with 8.7.1.7. A reboot of the MMs resolved this.
    Craig Syme
  • 3.  RE: Mobility Conductor isnt showing APs in dashboard when MDs are clustered
    Posted Feb 15, 2022 04:33 AM
    Had a TAC and we solved it. They said they had that issue already in their inbox.
    Problem is, that the MGMT-Server (Mobility Conductor) is not showing up at the controller when typing show mgmt-servers.  In the GUI you can find it under Configuration - System - More - General - Mon-Receivers -> in my case there was just "conductor" under IP and that doesnt work. So when I added my conductor IP it worked again.
    Cheers
    Raffael Hotz
  • 4.  RE: Mobility Conductor isnt showing APs in dashboard when MDs are clustered
    Posted Sep 25, 2023 10:36 AM
    Thanks, did the trick for me.  This was driving me crazy!@
    Jeff Davitt
    Converge Technology Solutions
