  • 1.  Mobility Conductor Licensing
    Posted Oct 29, 2024 09:05 AM
    I currently have the MC-VA-250 license on my Mobility Conductor. I am quickly approaching having 250 devices. I would like to expand my capacity. Can I just purchase another 250 license and add it to my existing 250 for a total of 500 devices on my MC?
    I found a post from a few years ago that said this was possible, I just want to make sure that's still the case and nothing has changed with licensing.
  • 2.  RE: Mobility Conductor Licensing
    Posted Oct 29, 2024 11:39 AM
    Yes you can, but you have to raise the Mobility Conductor License as well.
    The MC-VA-XX license is a sharable license required to terminate APs on a virtual controller. This is applicable for all APs terminating on x-amount of virtual Mobility Controllers.
    The MM-VA-XX or MCR-VA-XX license is needed for all managed Devices - Sum of all Mobility Controllers plus all APs managed by the controller Cluster(s).
    So if you have a Mobility Conductor in place you maybe have to raise the License account as well.
    For Reference - https://www.arubanetworks.com/techdocs/ArubaOS-8.x-Books/812/ArubaOS-8.12.0.0-Mobility-Conductor-Licensing-Guide.pdf
  • 3.  RE: Mobility Conductor Licensing
    Posted Oct 29, 2024 12:02 PM
    Yes.  Hopefully your VM resources for the VMC are already provisioned at or above the MC-VA-1K requirements.  If not, you'll need to allocate the additional resources and go through the "Increasing the Flash size" workflow as documented in the Virtual Appliance Installation Guide appendix.
    Carson Hulcher, ACEX#110
