Mobility Conductor (Mobility Master) default interface change
This thread has been viewed 21 times
  • 1.  Mobility Conductor (Mobility Master) default interface change
    Posted Sep 14, 2021 09:53 AM
    I'm setting up a Virtual Mobility Conductor and running into an issue with the default interfaces of GE 0/0/0 and GE 0/0/1 are automatically using a NIC that I didn't assign.  On the server I'm using I have a 10G connection for other VM's and two 1G ports I want to use for the Mobility Conductor.  However it's defaulting to the 10G connection and I need to know if there is a way to change that?
    Chris Smith
  • 2.  RE: Mobility Conductor (Mobility Master) default interface change
    Posted Sep 14, 2021 09:23 PM
    Have you checked to see what vmnic is mapped to the vSwitch in use by the virtual machine on the hypervisor side?
    Dustin Burns
    Senior Mobility and Access Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
