Mobility-Conductor : Questions about latency and unavailability
This thread has been viewed 19 times
  • 1.  Mobility-Conductor : Questions about latency and unavailability
    Posted Sep 10, 2021 08:49 AM
    Dear Arubers,
    I'm currently planning the configuration of two MC (mobility-conductor) for our WIFI architecture.
    We have two distinct DC and I have to check if Aruba Mobility architecture is compatible with our DCs. There are some details I've not found on datasheet :
    1) If one MC is installed on each DC, is there any limitation for latency maximum between the two DC ?
    2) How much data is exchanged between the two MCs ?
    3) If the two MCs are unreacahble, are CMs (Conductor-member) able to work properly ? If so, how long is this working possible?
    Can you help me on these few points ?
    Thanks a lot,
    JB
    Jules Bvt
  • 2.  RE: Mobility-Conductor : Questions about latency and unavailability
    Posted Sep 11, 2021 07:39 AM
    I would contact your Aruba Sales Engineer with those questions.  There are general answers to those questions, but a good answer would require a specific knowledge of your setup and what you are trying to accomplish.  In some situations, there would be a problem with latency.  In others, not so much.  Whether your deployment falls into the first or second category depends on your design and what services you are using.
