The release notes for each major version will tell you what you can upgrade from in the "upgrade procedure" section of the 8.10.0.0 portion. You can work backwards from there. Bookmark the consolidated release notes here: https://www.arubanetworks.com/techdocs/ArubaOS/Consolidated_8.x_RN/Content/Home.htm
For example, the Upgrade Procedure in 8.10.0.0 here has a chart about about upgrading for 8.3.x.x to 8.11.0.0 and the storage requirements, so I would take that to mean 8.3.x.x to 8.11.x.x is possible. Since you are on 8.2.x.x, I would open a technical support ticket to get very specific information about upgrading. It is possible you might have to do things like free up memory to make your upgrade successful.
HPE Design and Deploy Guides:
https://community.arubanetworks.com/support/migrated-knowledge-base?attachments=&communitykey=dcc83c62-1a3a-4dd8-94dc-92968ea6fff1&pageindex=0&pagesize=12&search=&sort=most_recent&viewtype=card------------------------------
Original Message:
Sent: Feb 12, 2023 08:48 PM
Subject: Mobility Conductor Upgrade
HI
We are currently running 8.2.1.0 and looking to upgrade to version 8.10.0.0
Can we do a direct upgrade or should we upgrade to 8.5.0.0 upgrade the controllers and then upgrade to 8.10.0.0?
Regards
