  • 1.  Mobility Conductor
    Posted Aug 24, 2021 07:08 AM
    One of our customers has a Mobility Conductor in a DC, there are two of them running active / standby - single MCR-VA-500.
    If they want to add a third Mobility Conductor in another DC for redundancy do they need to buy another MCR-VA-500, the other DC is connected via a L3 MPLS connection.
    Jason
  • 2.  RE: Mobility Conductor
    Posted Aug 24, 2021 11:26 AM
    Mobility conductor only goes in pairs (active / standby), it is not possible to create a cluster of 3, as far as I know.
    If you need more capacity, you can increase the size of the existing MCRs, or add the third as a separate standalone MCR.
  • 3.  RE: Mobility Conductor
    Posted Aug 24, 2021 11:55 AM
    Hello Herman,
    thanks for the reply.
    I found some information on page 68 of the Aruba AOS 8 Fundamental-Guide
    https://www.arubanetworks.com/assets/tg/TD_ArubaOS-8-Fundamental-Guide.pdf
    Jason
