Mobility Conductor/Mobility Controller AOS Upgrades
This thread has been viewed 69 times
  • 1.  Mobility Conductor/Mobility Controller AOS Upgrades
    Posted Jul 09, 2021 03:36 AM
    Hi All,
    Is anyone running version 8.8.0.0 or 8.8.0.1 on their Mobility Conductor and Controllers? Have you had any issues during the upgrade process or following the upgrade for the users? We are looking at upgrading from 8.6.0.4 in the near future so any gotchas would be helpful, especially for user side issues.
    Also, any idea how long it would take to complete? The wireless network this upgrade will be on is 1000+ APs.
    Regards
    Adrian
    Adrian Jones
  • 2.  RE: Mobility Conductor/Mobility Controller AOS Upgrades
    Posted Jul 10, 2021 09:20 AM
    The fastest upgrade would be a "standard" upgrade, which is NOT a live upgrade.
    How fast that would occur depends on your infrastructure.  A good rule of thumb is how long previous upgrades have taken (not live upgrade).
    There are many factors that would affect whether an upgrade is successful or not from 8.6 to 8.8, like whether you have existing issues, specific configurations, etc...  You should open a TAC case to see if anything you are doing would fundamentally block you from successfully upgrading.
