I looked everywhere but was not able to find how this works
The audit trail updated the Gateway with the following configuration:
lc-cluster group-profile auto_group_374
no auto-cluster-mode
no controller 20:4c:03:b2:08:82
controller 20:4c:03:b2:08:82 priority 128 vrrp-ip 0.0.0.0 rap-public-ip 136.47.197.25
Could it be that they forgot to remove this from the menu? I wonder I should open a TAC case, I looked everywhere but cannot find any documentation what this VPN termination feature can provide.
Martijn van Overbeek
Architect, Netcraftsmen a BlueAlly Company
Original Message:
Sent: Jan 31, 2025 04:07 PM
Subject: Mobility Controller Microbranch termination
Microbranch termination is only supported against a VPNC, the mobility persona is dedicated to campus connectivity. I don't know of a reason for enabling VPN termination on a mobility gateway but I suppose there might be some valid workflow that exists.
Carson Hulcher, ACEX#110
Original Message:
Sent: Jan 31, 2025 03:45 PM
Thank you Carson,
I am citing the Official Certification Guide, it only speaks about the Mobility Persona. Screenshot below.
Can you explain the purpose of the VPN termination button in the mobility persona?
Original Message:
Sent: Jan 31, 2025 03:32 PM
I don't know what that guide is trying to state, but Microbranch requires the VPNC be in a cluster.
https://arubanetworking.hpe.com/techdocs/central/2.5.8/content/aos10x/cfg/mb-deploy/mb_data_center_vpnc_conf.htm
Original Message:
Sent: Jan 31, 2025 01:13 PM
I am reading the HPE7-A01 book which states (page 576 of the hardcopy) that you can terminate microbranch APs on a Mobility Controller if you use manual mode. I did not know that and try to put it to the test.
The high availability option allows you to set the cluster to manual (see below)
I can slide a bar stating "VPN termination"
And I can also configure a Public IP address
The next step I thought is adding a microbranch to this gateway cluster
Unfortunately, whatever I try (build a new microbranch group or use an existing group), I cannot add the cluster to the microbranch.
What am I doing wrong or is the link below still valid and the HPE7-A01 book incorrect?
https://community.arubanetworks.com/discussion/does-aos10-gateway-mobility-persona-can-terminate-microbranch
