  • 1.  Mobility Master deployment
    Posted Mar 26, 2019 08:20 PM
    Hi guys,
    I have to deploy airwave as a management software for almost 300 network devices (I have almost 140 Aruba switches, Mobility Master Active-SdBy, 2 Hardware Mobility Controllers, 100 IAPs) in a server.
    I am also planning to deploy Mobility Master Act-Stb as a VM, but I need but to deploy them in the same server where I am planning to deploy the Airwave.
    Can anybody give some advice about the minimum requirements for the server?, any pros and cons of doing this?, maybe it is recommended not to do it, and install both software in independent hardware.
    Regards
  • 2.  RE: Mobility Master deployment
    Posted Mar 26, 2019 08:34 PM
    Airwave needs independent VM hardware.  Please review the VM installation guides for both products for more details.
  • 3.  RE: Mobility Master deployment
    Posted Mar 26, 2019 09:59 PM
    So long as your hypervisor has the CPU, RAM, and Disk accomodations required for the AirWave VM and the virtual MMS, you should be fine (all of mine run on the same hypervisor). That said, you need to ensure that you reserve the resources. Oversubscribing resources on your hypervisor will result in problematic performance of both AirWave and the VMMs.
