  • 1.  Mobility Master sizing document
    Posted Feb 27, 2020 06:15 AM
    Looking for an MM sizing document that actually specifies CPU and memory requirements. Found a glossy PDF that tells me part numbers in terms  no of supported clients but nothing of actual machine/vm spec
    been told mem requirements dependent on no of cpus defined.
    Also heard that if using airgroups you need to over spec the mmaster... by how much ?
    Rgds
    Alex
  • 2.  RE: Mobility Master sizing document
  • 3.  RE: Mobility Master sizing document
    Posted Mar 01, 2020 09:39 PM
    If you have the resources, you can always overspec the MM. It won't hurt, just requires more CPU and RAM. I don't have an answer for you on what is required for your needs, sorry. Also, if you build an MM, there is an easy process to do an in-place upgrade of the VM hardware to make the MM a larger more powerful machine. I think I wrote about it responding to someone in a previous question. The VMM does need to be taken down for a short period of time, but it is a quick, straightforward process.
    I hope this helps,
  • 4.  RE: Mobility Master sizing document
    Posted Mar 01, 2020 09:43 PM
    I found the previous post with the upgrade procedure. This procedure also works for virtual MCs.
    https://community.arubanetworks.com/t5/Wireless-Access/Upgrade-VM-hardware-for-MM/m-p/634598
    I hope this helps,
