Network Management
  • 1.  Modify Topology View
    Posted Jul 31, 2020 02:06 PM
    Hi there
    Im new with IMC and i ve a short question:
    How can i show in the topolgy view the device Label and the device Location? Didnt found that
    Thx
  • 2.  RE: Modify Topology View
    Posted Aug 02, 2020 01:33 AM
    Please refer 'Managing the network through topology' on pg.18 from below link:
    https://support.hpe.com/hpesc/public/docDisplay?docId=emr_na-c05367573
  • 3.  RE: Modify Topology View
    Posted Aug 04, 2020 03:25 AM
    Hi
    Invalid or corrupt PDF:
  • 4.  RE: Modify Topology View
    Posted Aug 04, 2020 05:19 AM
    I am not sure why that link is not working for you.
    It working fine for me, are you seeing any error?
    https://support.hpe.com/hpesc/public/docDisplay?docId=emr_na-c05367573 Network Topology.JPG
    Thanks!
  • 5.  RE: Modify Topology View
    Posted Aug 04, 2020 07:56 AM
    @Fabio_R  It is working for me. Able to open it. Try a different browser or just copy paste the link in google
  • 6.  RE: Modify Topology View
    Posted Aug 05, 2020 01:36 AM
    Has my solution helped you resolve the query or do you need more assistance.
    Thanks!
  • 7.  RE: Modify Topology View
    Posted Aug 07, 2020 02:30 PM
    Hi
    How to show the network topology i've found yet before, what im looking for is the device location
  • 8.  RE: Modify Topology View
    Posted Aug 10, 2020 03:49 AM
    When you right-click on the topology and select Device Label, you have the following options...
    There is currently no option to display the SNMP SysLocation on the network topology, unless you manually add Notes or other objects to designate different areas. You could reach out to your HPE Sales/Account Management contact to open a feature request if you need to have it added in a future version.
