You can ask Aruba Support to add one or more additional Galleria or Custom skins.
Original Message:
Sent: Sep 21, 2021 05:33 PM
Subject: Modifying Default Skins in Clearpass
What is the best practice for creating or modifying the default skins? I would like to use the Galleria 2 skin for the Guest wi-fi self registration but I can't seem to copy or duplicate the default before changing anything is this a normal practice or should I be using the Custom 1-2 skins and creating special HTML and CSS code?
Eric Orosz
