Wired Intelligent Edge
  • 1.  Monitor HP Switch 5412zl (J8698A) Modules via SNMP
    Posted Jul 28, 2021 08:06 AM
    Hello everyone,
    We use HP Switch 5412zl (J8698A) with 12 Switch modules
    I'm running Icinga to monitor the Switch.
    Modules G J9534A failed after thunderstorms. The others Modules were ok
    But the Swith modules were not monitored.
    Is there the possibility to query via SNMP status (up / down) of built-in switch modules?
    Thx
  • 2.  RE: Monitor HP Switch 5412zl (J8698A) Modules via SNMP
    Posted Jul 29, 2021 02:59 AM
    Hello @monitorjunkie ,
    Yes, it can be monitored via snmp on monitoring tool.
    You wil get notification/alert during hardware failure.
    Thanks!
  • 3.  RE: Monitor HP Switch 5412zl (J8698A) Modules via SNMP
    Posted Jul 29, 2021 08:51 AM
    Hello  akg7
    Can you explain it to me?
    Which OID or MIB I find the notification.
    Under OID HPICFNOTIFICATIONS 1.3.6.1.4.1.11.2.14.12 I find nothing
    Thx
  • 4.  RE: Monitor HP Switch 5412zl (J8698A) Modules via SNMP
    Posted Jul 31, 2021 09:30 AM
    If you want to query the status of the modules you can use the OID entOperState 1.3.6.1.2.1.131.1.1.1.3 from the entity state MIB. Value 3 means that the entity is operable, 2 means totaly unoperable.
    http://www.circitor.fr/Mibs/Html/E/ENTITY-STATE-MIB.php
    INTEGER unknown(1), disabled(2), enabled(3), testing(4)
    Represents the possible values of operational states. A value of 'disabled' means the resource is totally inoperable. A value of 'enabled' means the resource is partially or fully operable. A value of 'testing' means the resource is currently being tested and cannot therefore report whether it is operational or not. A value of 'unknown' means that this resource is unable to report operational state.
    You can use it together with the OIDs entPhysicalDescr or entPhysicalIndex from the ENTITY MIB (rfc2737.mib) to identify which module corresponds to which index.
    Something very helpful is the commands walkmib and getmib followed by an OID on the CLI of the switch. This commands allow you to test particular OID directly on the CLI of the switch . You can use the OID in numeric or textual form.
  • 5.  RE: Monitor HP Switch 5412zl (J8698A) Modules via SNMP
    Posted Aug 02, 2021 01:28 AM
    Hello
    Very well. Excellent information.
    Very helpful
    Thank you
