Network Management
  • 1.  Monitor Only mode question
    Posted Dec 13, 2016 09:10 AM
    Network setup looks like:
    - IAP clusters in several Groups
    - AirWave appliance
    - ClearPass appliance
    Due to Aruba's default Captive Portal certificate revocation we need to replace it with new public certificate (wildcard, btw) using AirWave on several locations. Those clusters are in "Monitor Only" mode at the moment, so my question is can we get the certificate uploaded to them without moving them to a "Management" mode (I am aware that firmware upgrade can happen in Monitor mode)? Thanks in advance.
    AlanFord
  • 2.  RE: Monitor Only mode question
    Posted Dec 13, 2016 10:09 AM
    In a word no.
    However you can apply changes whilst in monitor mode If you have a maintenance window scheduled in Airwave for your devices, Airwave will push the configuration it has onto your devices regardless of them being in monitor-only mode.
  • 3.  RE: Monitor Only mode question
    Posted Dec 13, 2016 12:38 PM
    Thanks, appreciated!
    AlanFord
