Comware
  • 1.  Monitoring HPE FlexFabric 5700
    Posted Oct 20, 2016 05:29 AM
    Customer have two HPE FlexFabric 5700 switches in his SAN. He would like to monitor the switch health, port statistics, performance etc. We have HPE OneView to monitor servers, but I found, that OneView supports only Cisco Nexus switches. Is there any free grafical tool, that can monitor 5700 switches?
    Thank you.
    Tom
  • 2.  RE: Monitoring HPE FlexFabric 5700
    Posted Oct 25, 2016 06:48 AM
    We use cacti.
    http://cacti.net/
    Regards
  • 3.  RE: Monitoring HPE FlexFabric 5700
    Posted Jul 20, 2018 04:03 AM
    Hi!
    Can you tell the template you using for your 5700?
  • 4.  RE: Monitoring HPE FlexFabric 5700
    Posted Oct 25, 2016 04:42 PM
    Tomas,
    There may be an HPE OneView Plug in that supports the Comware switches.   Might be worth a look.
    Otherwise, Stanford University has built a pretty comprehensive web site of monitoring tools.  Both free and commercial are listed.  Check it out here...
    While I cannot recommend one over another, a lot of sites are using the Nagios tool.  You'd have to take a look at it and see if it does what you need.
    David
  • 5.  RE: Monitoring HPE FlexFabric 5700
    Posted Oct 25, 2016 07:37 PM
    Here we use Zabbix (free) and IMC-HPE (licensed)
  • 6.  RE: Monitoring HPE FlexFabric 5700
    Posted Jul 16, 2018 08:22 AM
    Do you have any zabbix template for HPE FlexFabric 5920 switch? I think the 5700 series template is good for this.
