Become a Member
Hi Aruba,
I recently purchased Aruba AP 515 and want to mount it on the ceiling. I have a flat ceiling with dry wall materials. Please advise on what mounting kit I should get with part number and where I can get it. Appreciate your help very much.
I would recommend a AP-MNT-MP10-E. This is a flat surface mount, and can be attached to single and dual-gang electrical boxes as well. See attached mounting options for the 5xx series.
Attachment(s)
Hi Dustin,
That's a 10pk. Is there singles which I can buy?
Yes there are individual type-E mounting brackets available. Check the AP-5xx ordering guide for the specific part number.
Good resource about the AP-500 serie mount options can be find here.
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=31544
De AP-MNT-MP10-D also does the job and have a smaller footprint then the AP-MNT-MP10-E, both are for flatsurfaces or wall mount.
Link to the AP-500 ordering guide here:
https://www.arubanetworks.com/assets/og/OG_AP-500Series.pdf
Thank you, mkk.
https://www.arubanetworks.com/techdocs/hardware/accessories/AP-MNT-E/AP-MNT-E_Install_Guide.pdf
Thank you, efisher214.
