  • 1.  Move from EAP-Peap to TLS Auth method
    Posted Jan 23, 2025 05:10 AM
    Edited by khaled0moh Feb 07, 2025 03:20 AM
    hi experts,
    i have was running wifi staff on EAP-PEAP and ssid configured with radius it's working fine.
    but now need to apply eap-tls and the issue client shown this message while connecting "unable to connect, you need certificate to sign-in"
    so i checked the certificate already pushed on user and Compter certificate
    this radius certificate get from clearpass CSR and signed by ADCS.
    cppm service:
  • 2.  RE: Move from EAP-Peap to TLS Auth method
    Posted Jan 23, 2025 06:12 AM
    Hi
    Have you configured the client to utilize EAP-TLS for the authentication?
    It's best done with a GPO with the WiFi 802.1x settings, where you select all needed options for the authentication.
    You should select the Root CA to trust and also give the name in the ClearPass RADIUS certificate.
    Do you get any error messages in the Access Tracker?
    Best Regards
    Jonas Hammarbäck
    Aranya AB
  • 3.  RE: Move from EAP-Peap to TLS Auth method
    Posted Jan 23, 2025 08:00 AM
    Hi Jonas,,
    i'm trying manually on one machine if it's success will push to all with GPO.
    but i think this machine issue because access trucker not receiving any alert after user not able to connect on ssid and shown certificate error.
  • 4.  RE: Move from EAP-Peap to TLS Auth method
    Posted Jan 23, 2025 08:09 AM
    In the screenshot of your certificates I can only see Server Authentication as intended purpose. Verify that your client certificates have Client Authentication as intended purpose in the certificate.
    Is the RADIUS certificate on the ClearPass server issued by the same CA as the client certificate, cadd-WIN-QBIDRM98CDO-CA?
    Under the Advanced settings, have you selected how the machine should authenticate? Either with user or computer certificate or utilize both. If both are selected the machine will use the machine certificate if no user is logged in and the user certificate as soon as a user has logged in to Windows.
    Best Regards
    Jonas Hammarbäck
    Aranya AB
  • 5.  RE: Move from EAP-Peap to TLS Auth method
    Posted Jan 23, 2025 08:39 AM
    ok, thank you much will verify all those points.
  • 6.  RE: Move from EAP-Peap to TLS Auth method
    Posted Feb 06, 2025 03:32 AM
    Edited by khaled0moh Feb 07, 2025 03:19 AM
    solved, finally :) :)
    the issue was computer and user certificate, now the role is included both and user able to access via EAP-TLS
    Best Regards Jonas ,,thanks
  • 7.  RE: Move from EAP-Peap to TLS Auth method
    Posted Feb 06, 2025 05:23 AM
    in access tracker the host rejected but user able to access internet.. is it normal behaviour ?
  • 8.  RE: Move from EAP-Peap to TLS Auth method
    Posted Feb 07, 2025 12:49 AM
    Based on that screenshot, it rejected the connection when authenticating as the machine then accepted the user authentication request.
    Hard to say why without knowing your roles and enforcement profiles.
    For Windows devices, I'd suggest using EAP-TEAP as the method as it can authenticate both machine and user in the same request.
    This helps solve the issue if the user does not have a certificate it will still remain connected (assuming you allow machine authentication) after login.
    Here's another thread with more details: EAP-TEAP | Security and also a good guide from HPE ClearPass TEAP Configuration Guide.
    Only thing I would do differently with the TEAP configuration guide is use EAP-TLS for both methods instead of EAP-MSCHAP (page 18).
  • 9.  RE: Move from EAP-Peap to TLS Auth method
    Posted Feb 07, 2025 01:28 AM
    Edited by khaled0moh Feb 07, 2025 03:18 AM
    yes, with TEAP i tested it't working perfectly.
