  • 1.  Moving a Proxmox VM from one stack to another
    Posted 27 days ago
    I know it is officially unsupported, but was wondering if someone has experience moving a Conductor VM created on a Proxmox from one stack to another. I tried dd, cp -r, and scp, but all fail, the VM will not boot. Is there something special I need to do to move the VMs or is it just easier to build from scratch and move the licenses.
    Thank you.
    Martijn van Overbeek
    Architect, Netcraftsmen a BlueAlly Company
  • 2.  RE: Moving a Proxmox VM from one stack to another
    Posted 26 days ago
    Fails on what?  Technically, even within vSphere, you're supposed to shut down the VM and then migrate the VM.
    Also unsupported in just about every way, but I've got multiple MCR moving around seamlessly within VM Essentials.
    Carson Hulcher, ACEX#110
  • 3.  RE: Moving a Proxmox VM from one stack to another
    Posted 26 days ago
    I think I found something, the people I work with missed copying the second drive, I report back in if it works! Thanks for checking in.
