Location Services
  • 1.  Moving AP's between controllers
    Posted Jun 15, 2015 11:44 AM
    Hi, is it possible to move APs between a master and local controller ?
    Is it advisable ?
  • 2.  RE: Moving AP's between controllers
    Posted Jun 15, 2015 11:47 AM
    Yes. Are you using HA, LMS or VRRP redundancy?
    Tim
  • 3.  RE: Moving AP's between controllers
    Posted Jun 15, 2015 11:51 AM
    Hi Tim, i don't think there's any redundancy in place
  • 4.  RE: Moving AP's between controllers
    Posted Jun 15, 2015 11:55 AM
    OK. You can change the LMS IP in the AP system profile which will move the APs. Be sure the other controller has either the same VLANs configured or VLAN-IDs mapped to the VLAN names.
