  • 1.  MPSK feature - SSID Vlan configuration
    Posted Jun 25, 2021 08:53 AM
    Hi all,
    I am trying to setup a SSID that will cover 4 different vlans. Each vlan will have its own passphrase, meaning that the user will be placed undera certain vlan based on the passphrase provided by him. I used the MPSK local settings: I have defined 4 different roles, then I set the MPSK table to map each role with a specific passphrase.
    I am wondering now what is the correct Vlan settings under Aruba Central SSID config: Dynamic or Native. It can't be static for sure.
    Thanks in advance for your help.
    Sinda FKAIER
  • 2.  RE: MPSK feature - SSID Vlan configuration
    Posted Jun 25, 2021 10:28 PM
    generally you can set it to static with some VLAN ID. the aim here is that if you see users in that restricted VLAN then you know that there was an issue with the MPSK user-role.
