From a quick Google search, Ubiquiti appears to have recently introduced a feature called PPSK (Private PSK), similar to MPSK in Aruba and ISPK in Cisco, amongst others. I found this post explaining how to set it up: https://community.ui.com/questions/Proof-of-Concept-Private-PSK-Personal-PSK-PPSK-with-dynamic-VLAN-via-RADIUS-MAC-auth/68f3097a-dcc1-4c31-bb51-ede39e706e30
Since this was posted on Airheads, I'll assume you're using ClearPass as your RADIUS server to handle the MAC auth request? If using ClearPass, it looks like the enforcement is leveraging "Tunnel-Password", so set the Type to RADIUS:IETF, Name is Tunnel-Password, and Value to the key you expect the device to send.
Michael Haring
Original Message:
Sent: Nov 24, 2023 09:10 AM
Subject: MPSK with Third Party Device
Hey guys, okay?
Has anyone integrated the MPSK function with a third-party device?
Without being Cisco and Aruba!!
I would like to try to make it work with a UNIFI controller, but I am having difficulties. Is this possible?
If anyone has already done this, I would just like to know more or less which configuration was used.
Thanks in advance.
