Become a Member
The MSM466-R is a dual radio with 3 N-type connectors for each radio that are color coded red, blue, and green. Does anyone know which connector is horizontal and which are vertical?
The colours on the AP match the colours on the antenna supplied by HP.
Also check out that same AP at the beach!
http://h30507.www3.hp.com/t5/HP-Networking/Want-a-Wi-Fi-access-point-at-the-beach/ba-p/126485
External antenna power settings:
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c03459394/c03459394.pdf
Antenna connector colour guide:
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c02697169/c02697169.pdf?HPBCMETA::
(for a different model, but it may help you find the right data).
