Hi
I have a customer running MSM710 controllers with the latest software, and internally their wireless setup works absolutely fine. The LAN port is connected to the corporate network and WPA keys are used to allow for security for internal users.
The have a seperate DSL feed via a basic router and wish to connect this to the Internet Port of the MSM710 to allow for basic unrestriced guest lan access. I have follow multiple guides from HP on how to set this scenairo up but i think they are often too complicated (VLANs, RADIUS etc). I simply want to be able to connected to a GuestLAN SSID and have a DHCP address assigned which routes traffic out via the internet port.
Could anybody shed some light on the simplest way to set this up?
I have tried and failed on multiple occasions to put a config in place that will do this.
HTML forms authentication is fine if necessary but ideally it would be just a WPA key to be entered by the guest to gain access.
Currently I have the internet port as a DHCP client, a Guest VSC with client data tunnel routed, a DHCP scope configured on the VSC and HTML authentication enabled. I pickup the IP address OK from the wireless connection but am unable to see the MSM710 controller or route traffic through it.
Any help much appreciated.
Dan
