Comware
  • 1.  MSR2003AC -> MSR2003AC tunnel issues.
    Posted Jul 26, 2024 10:03 AM
    Hi HPE/ARUBA community!
    I have a situation running two(2) MSR2003AC routers one i a city office and one in a small factory. I have successfully managed to install the two routers and set them up using L3 port mode for WAN and LAN (only one vlan exists VLAN 1) in CFG the two routers can communicate with each other over a GRE/IPSEC tunnel, the intention is to use this as a permanent bridge joining the two lan networks 172.18.0.0/16 and 172.19.0.0/16 respectively, if a client on either LAN tries to ping any host on the other LAN it just works which is great, servers or other clients can be accessed and so on. The problem I'm facing is when external users log into the network using a L2TP/IPSEC VPN tunnel to router1 running 172.18.0.0/16 network and then tries to access router2s lan network 172.19.0.0/16 this just don't work. I can set the VPN client (windows native vpn) to add a route to 172.18.0.0/16 and the client gets full access to that network but if i add a route to 172.19.0.0/16 thru 172.18.1.1 or tunnel GW 192.168.254.1 i just get no response on ICMP ping 172.19.1.1 or trying to access a webserver on 172.19.10.1 can anybody kindly provide me with any pointers?
    Best regards,
    Rick.
  • 2.  RE: MSR2003AC -> MSR2003AC tunnel issues.
    Posted Jul 31, 2024 05:22 AM
    Edited by MSRUser19700101 Jul 31, 2024 05:30 AM
    1.
    Maybe i should simplify the problem a bit, so what is not working is that users accessing the internal network thru L2TP/IPSEC VPN to one MSR2003AC(VPN node) router can't reach another network connected thru a IPSEC/GRE tunnel between said router and another identical router.
    I have temporarely disabled the IPSEC cfg over the router -> router GRE tunnel(bridge) for convenience which can be seen in the config provided below, its not a error.
    And removed some extra stuff such as attack defens for now to keep it to a bare minimum.
    What currently works:
    (user)lt2p/ipsec vpn --> router A(1.1.1.1) --> LAN(172.18.0.0/16).
    (user) LAN A(172.18.0.0/16) --> (gre/ipsec) --> LAN B(172.19.0.0/16).
    (user) LAN B(172.19.0.0/16) --> (gre/ipsec) --> LAN A(172.18.0.0/16).
    What does NOT work and i need help with:
    (user) lt2p/ipsec vpn --> router A(1.1.1.1) --> (gre/ipsec) --> router B(2.2.2.1) --> LAN(172.19.0.0/16).
    2.
    I also wonder if anybody out there has the latest firmware for these routers, or maybe i already have the latest versions of boot+fw ?!? Current version is: msr2000-cmw710-boot-r0707p12
    I have attached the cfg file for the VPN capable node.
     version 7.1.064, Release 0707P12
     sysname mydomain
     clock timezone zone1 add 02:00:00
     packet-filter default deny
    aspf policy 1
     detect dns
     detect ftp
     detect http
     detect rtsp
     detect smtp
     ip pool l2tp-p2mp-ipv4pool1 192.168.254.200 192.168.254.250
     ip pool l2tp-p2mp-ipv4pool1 gateway 192.168.254.1
    nat address-group 0
     address interface GigabitEthernet0/0
     dhcp enable
     dns proxy enable
     dns server 1.2.3.4
     password-recovery enable
    vlan 1
    controller Cellular0/0
    interface Aux0
    interface Virtual-Template0
    interface Virtual-Template1
     ppp authentication-mode ms-chap-v2
     remote address pool l2tp-p2mp-ipv4pool1
     ip address 192.168.254.1 255.255.255.0
     tcp mss 1280
    interface NULL0
     port link-mode route
     ip address 1.1.1.1 255.0.0.0
     packet-filter name GE0/0-inbound inbound
     packet-filter name GE0/0-outbound outbound
     aspf apply policy 1 outbound
     nat outbound 2000
     ipsec apply policy ipsec-permtun-pol1
    interface GigabitEthernet0/1
     ip address 172.18.1.1 255.255.0.0
     packet-filter name GE0/1-inbound inbound
     packet-filter name GE0/1-outbound outbound
    interface Tunnel0 mode gre
     ip address 192.168.240.1 255.255.255.0
     tcp mss 1280
     source GigabitEthernet0/0
     destination 2.2.2.1
     gre key 123456789
     gre checksum
    security-zone name Local
    security-zone name Trust
    security-zone name DMZ
    security-zone name Untrust
    security-zone name Management
     scheduler logfile size 16
    scheduler job greupdate1
     command 0 python pupdategre.py
    scheduler schedule greeupdateschedule1
     user-role network-admin
    scheduler schedule greupdateschedule1
     job greupdate1
     time repeating interval 5
    line class aux
    line class tty
     user-role network-operator
    line class vty
    line aux 0
     speed 115200
     authentication-mode scheme
    line vty 0 1
    line vty 2 63
     ip route-static 0.0.0.0 0 GigabitEthernet0/0 1.1.1.250 permanent
     ip route-static 172.19.0.0 16 Tunnel0 permanent
     ssh server enable
     sftp server enable
     ntp-service unicast-server se.pool.ntp.org
    acl basic 2000
     rule 0 permit source 172.18.0.0 0.0.255.255
    acl advanced 3100
     rule 0 permit gre source 1.1.1.1 destination 2.2.2.1 0
    acl advanced name GE0/0-inbound
     rule 100 deny tcp destination-port eq 22
     rule 105 deny tcp destination-port eq 8080
     rule 106 deny tcp destination-port eq 8443
     rule 65534 permit ip
    acl advanced name GE0/0-outbound
    acl advanced name GE0/1-inbound
    acl advanced name GE0/1-outbound
     password-control enable
     undo password-control aging enable
     undo password-control history enable
     password-control length 6
     password-control login-attempt 3 exceed lock-time 10
     password-control update-interval 0
     password-control login idle-time 0
     password-control complexity user-name check
    domain system
     authentication ppp local
     domain default enable system
    role name level-0
     description Predefined level-0 role
    role name level-1
     description Predefined level-1 role
    role name level-2
     description Predefined level-2 role
    role name level-3
     description Predefined level-3 role
    role name level-4
     description Predefined level-4 role
    role name level-5
     description Predefined level-5 role
    role name level-6
     description Predefined level-6 role
    role name level-7
     description Predefined level-7 role
    role name level-8
     description Predefined level-8 role
    role name level-9
     description Predefined level-9 role
    role name level-10
     description Predefined level-10 role
    role name level-11
     description Predefined level-11 role
    role name level-12
     description Predefined level-12 role
    role name level-13
     description Predefined level-13 role
    role name level-14
     description Predefined level-14 role
    user-group system
    local-user admin class manage
     service-type ssh terminal http https
     authorization-attribute user-role network-admin
    local-user vpntestuser class network
     password cipher $thisisafakehash=
     access-limit 2
     service-type ppp
     authorization-attribute user-role network-operator
    public-key peer 172.19.1.1
     public-key-code begin
       123fakenmb
     public-key-code end
     peer-public-key end
    cwmp
     cwmp enable
    ipsec transform-set ipsec-p2mp-set1
     encapsulation-mode transport
     esp encryption-algorithm aes-cbc-256
     esp authentication-algorithm sha256
     ah authentication-algorithm sha256
     pfs dh-group14
    ipsec transform-set ipsec-permtun-set1
     esp authentication-algorithm sha512
     pfs dh-group24
    ipsec policy-template ipsec-permtun-temp1 1
     reverse-route dynamic
     reverse-route preference 100
     reverse-route tag 1000
    ipsec policy ipsec-permtun-pol1 10 isakmp template ipsec-permtun-temp1
    l2tp-group 1 mode lns
     allow l2tp virtual-template 1
     undo tunnel authentication
     tunnel name l2tp-p2mp-tunnel
     l2tp enable
     ike dpd interval 5 periodic
    ike proposal 1
     dh group24
     sa duration 60
     description sk <-> kh tunnel, highest possible settings.
    ike proposal 2
     dh group14
     authentication-algorithm sha384
     sa duration 60
     description MS-W10> Compatible
    ike keychain ikep2mpkey1
     match local address GigabitEthernet0/0
     pre-shared-key address 0.0.0.0 0.0.0.0 key cipher $mysecretkeyhash
    ike keychain ikepermtunkey1
     pre-shared-key address 2.2.2.1 255.255.255.0 key cipher $mysecrethash
     ip http port 8080
     ip https port 8443
     ip http enable
     ip https enable
    return
    Rick.
  • 3.  RE: MSR2003AC -> MSR2003AC tunnel issues.
    Posted Aug 07, 2024 07:25 AM
    Latest FW version is 7.10 R6749P21
    Your version is very old from 2020.
    You can get it with valid support contract from networkingsupport.hpe.com portal
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
  • 4.  RE: MSR2003AC -> MSR2003AC tunnel issues.
    Posted Aug 24, 2024 06:31 AM
    Edited by MSRUser19700101 Aug 24, 2024 06:31 AM
    Hi Gozrazd,
    Thank you for the reply! Yeah i can find software on the HPE portal(your provided link) but i can't unfortunately access the firmware updates there due to the fact that i have no HPE customer account, since i bought my routers factory refurbished second hand. So in short HPE won't give it to me, and the support has just stopped answered per email after some i think well indented attempts to figure out if i could have access.
    Generally:
    I managed to fix my VPN/IPSEC problems, trick is to not mix GRE & GRE P2MP tunnels since ACL's don't want to "allow" the gre tunnel to become IPSEC:ed and only
    lets the GRE P2MP tunnel to become IPSEC:ed + other related routing issues.
    1. Do anybody know what the sequence number means in IPSEC cfg? This is unclear in the HPE techhub.
    2. Has anybody managed to get TCL cli on the routers to take custom functions / actually respect the "source" directive it wont allow me to run custom functions so that i can have my script run periodically thru schedule, currently i solve a problem of DDNS and IP's using the python client on the routers and that works, but loading the interpreter each time one an hour creates a network slowdown / glitch for 2-3sec due to CPU consumption.
    Best Rickard.
  • 5.  RE: MSR2003AC -> MSR2003AC tunnel issues.
    Posted Aug 24, 2024 09:57 AM
    Hi Rickard.
    You can check the support status of your router on https://support.hpe.com/connect/s/?card=wc
    Refurbished equipment bought via authorized distributor/reseller has the same warranty/support status as new equipment.
    Comware gear is the exception in Aruba land as it has only 1 year warranty. But you can always buy a Support Pack for it. It's not that expensive and if this will be/is a production, it's well worth it.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
