Comware
MSR954 JH299A 4G eth-channel won't go up after reboot
  • 1.  MSR954 JH299A 4G eth-channel won't go up after reboot
    Posted Oct 14, 2023 01:51 PM
    Edited by lennutrajektoor Oct 14, 2023 01:56 PM
    Hello!
    I've got MSR954 JH299A 4G router which won't bring up the eth-channel after it reboots the system regardless of the configuration. This results in NTP and DNS services unable to serve the clients, also the clients can't access the internet as the interface is down. The only way to bring it up is to ping a random site by its IP-address on which the physical interface is brought up and everything works. The issue has been present since I got the device and it has to be a setup related problem as I have the same issue on another MSR954 JH299A if it runs on 4G.
    On technical level everything is sound as the SIM is inserted and functional, subscription is set and when the interface brings itself up everything works flawlessly.
    The setup is following:
    DIALER-GROUP 1 RULE IP PERMIT
    APN-PROFILE 0
    APN STATIC internet // provider specified only required APN parameter
    CONTROLLER CELLULAR 1/0
    ETH-CHANNEL 0
    MODE LTE
    INT ETH-CHANNEL 1/0:0
    UNDO SHUT
    IP ADDRESS CELLULAR-ALLOC
    APN-PROFILE APPLY 0
    DIALER CIRCULAR ENABLE
    DIALER-GROUP 1
    DIALER NUMBER *99#
    NAT OUTBOUND
    IP ROUTE-STATIC 0.0.0.0 0 ETH-CHANNEL 1/0:0
    DNS SOURCE-INTERFACE ETH-CHANNEL 1/0:0
    I tried to resolve the issue by creating a job which pings my own server to get it up but the reality is after rebooting the scheduler is clear from previously scheduled jobs, thus making forcing to find a solution for the root of the problem as the router is deployed at customer's premise and I can't access it physically. To make it accessing the internet the need is to log into the router and ping by an IP-address.
    After reboot command "disp ip int eth-channel" shows:
    Eth-channel1/0:0 current state: DOWN
    Line protocol current state: UP(spoofing)
    After ping:
    Eth-channel1/0:0 current state: UP
    Also, the eth-channel tends to shut down itself after an idle period on the interface.
    Command "disp cellular 1/0" shows:
      Hardware Information:
        Model: MC7304
        Manufacturer: Sierra Wireless, Incorporated
        Modem Firmware Version: SWI9X15C_05.05.58.00 r27038 carmd-fwbuild1 2015/03/04 21:30:23
        Modem Boot Version: SWI9X15C_05.05.58.00 r27038 carmd-fwbuild1 2015/03/04 18:38:46
        Firmware Unique ID = 005.026_000
        Firmware Build ID = 05.05.58.00_GENEU-4G
        Configuration Unique ID = 005.026_000
        Configuration Build ID = 05.05.58.00_GENEU-4G
        PRI Version: 9904567 05.00
        International Mobile Equipment Identity (IMEI): 356853053359255
        International Mobile Subscriber Identity (IMSI): 248022139274040
        Hardware Version: 1.0
        Modem Status: Online
        Modem Status: IPv4 Active.
        Modem Status: IPv6 Unkown.
      Profile Information:
        Profile index: 1
          PDP Type: IPv4v6
          Header Compression: Off
          Data Compression: Off
         Access Point Name (APN): internet
          Authentication: NONE
      * - Default profile
      Network Information:
        Current Service Status: Service Available
        Registration Status: Registered
        Current Service: Combined
        Current Roaming Status: Home
        Current Data Bearer Technology: LTE
        Network Selection Mode: Automatic
        Current IP address Mode: Cellular-alloc
        Mobile Network Name: a
        Mobile Country Code (MCC): 248
        Mobile Network Code (MNC): 02
        Location Area Code (LAC): 65534
        Tracking Area Code(TAC): 2021
        Cell ID: 256319509
      Radio Information:
        Technology Preference: LTE only
        Technology Selected: LTE
        Configured LTE Band = 1,3,7,8,20
        Configured GSM Band = GSM 1800,E-GSM 900,P-GSM 900,GSM 850,GSM 1900
        Configured WCDMA Band = WCDMA 2100,WCDMA 1900,WCDMA 850,WCDMA 900
     LTE related info:
        Current RSSI: -66 dBm
        Current RSRQ: -12 dB
        Current RSRP: -100 dBm
        Current SNR: 1 dB
        Tx Power: Invalid
        Active Band = E-UTRA Operating Band 3
      Modem Security Information:
        PIN Verification: Disabled
        PIN Status: PIN Requirement Disabled
        Number of PIN Retries Remaining: 3
        Number of PUK Retries Remaining: 10
        SIM Status: OK
            ICCID: 89372021180330050115
      Error Information:
        IPv4 dialing failed: 0x00: No error in the request
        IPv6 dialing failed: N/A
    GPS Information:
      GPS Info:
        GPS State: Enabled
        GPS Mode Configured: Standalone
    I can't get the eth-channel interface up by command "undo shutdown" as its status will remain unchanged - Eth-channel1/0:0 current state: DOWN
    Firmware is on Comware version 7.1.064, Release 0809P33 but that's is not an issue as the same problem has been present on the firmwares prior that one.
    NTP is configured and enabled but that won't change the behavior of the physical interface.
    Can someone advice what else configuration has to be applied to get 4G eth-channel up as its unwillingness to get up when the setup is applied is the root of the issue. I've read all the MSR954 configuration manuals and no, I haven't found anything that would help me resolve the issue by myself.
