Wired Intelligent Edge
Multicast flood although IGMP enabled
  • 1.  Multicast flood although IGMP enabled
    Posted Dec 03, 2013 05:37 AM
    in a dependance, connected with fibre directly to our LAN (one vlan), we have 3 switches (2524), one 2510.
    I can monitor them with Fluke Optiview Analyzer.
    The problem is: there ist Multicast traffic almost all the time.
    Port Out utilization is 0,4%, there from about 80-90% Multicasts.
    This can varie up to 96% and sometimes it comes to connection aborts.
    Clients are PCs and Thinclients, which connect to Terminalservers with NLB.
    Therefore they need multicasts, which i enabled via Webinterface.
    This is the same config, which we use in several other dependancies, which do not have this problem.
    Except the thin clients, which are only in this location.
    Could this be the reason?
    Regards
    Rainer
  • 2.  RE: Multicast flood although IGMP enabled
    Posted Dec 05, 2013 09:45 PM
    Check that the multicast querier is disabled except on the switch you want to be querier.
  • 3.  RE: Multicast flood although IGMP enabled
    Posted Dec 09, 2013 02:47 AM
    multicast querier is disabled on all the switches in the department.
    Strange, that there are multicasts on all ports almost all the time.
