Cloud Managed Networks
  • 1.  MultiEdit + VSX?
    Posted Mar 14, 2022 07:16 PM
    Wondering if there are any caveats and guidance on managing a VSX enabled device using MultiEdit from Aruba Central?
    For example, if I make a change to remove a VLAN that is synced on both devices, or update a prefix-list, should I edit both devices in Central or just the VSX primary? How will Aruba Central handle the configuration change that is synced automatically to the VSX secondary?
    Chris Denham
  • 2.  RE: MultiEdit + VSX?
    Posted Mar 14, 2022 07:28 PM
    check this link which outlines the commands not supported in MultiEdit mode.
    https://help.central.arubanetworks.com/2.5.4/documentation/online_help/content/nms/aos-cx/cfg/conf-cx-multiedit-cmds-nt-sup.htm
  • 3.  RE: MultiEdit + VSX?
    Posted Mar 14, 2022 07:33 PM
    Thanks - I have seen this command list, but doesn't answer my question :)
    Chris Denham
  • 4.  RE: MultiEdit + VSX?
    Posted Mar 14, 2022 07:54 PM
    There is also another note in Central that VSX and template based group for those switches is not supported.
    Now using Multiedit i think you have 2x choices, one being the VSX primary being the single-source of truth for configuration  and the second is to not use VSX-sync when using Multiedit
    I generally go with using VSX primary.
