As far as i know, Local users in MAC List will be used across all SSID. So that means only one list can be used.
For this purpose, you would need Aruba Clearpas or an External Radius server (like FreeRadius)
Shpat | ACEP | ACMP | ACCP | ACDP
Just an Aruba enthusiast and contributor by cases
If you find my comment helpful, KUDOS are appreciated.
Original Message:
Sent: May 24, 2025 07:33 AM
Subject: Multiple MAC Auth lists
We have an Aruba Instant solution managed by A.Central with Cloud Guest. Looking to configure multiple (different) MAC Whitelists for different PSK SSIDs.
e.g.
SSID-1 uses MAC-Whitelist-1
SSID-2 uses MAC-Whitelist-2
etc
Have tried local 'users' & Client Profiles but can only seem to create a single MAC Whitelist which can be used by multiple SSIDs.
Have also tried assigning a Client Tag as a result of 'Username' (username from the MAC Whitelist) but this doesn't seem to work.
Any suggestions welcomed.
Many thanks
