Wired Intelligent Edge
AOS-CX NAE developer documentation
  • 1.  AOS-CX NAE developer documentation
    Posted May 19, 2022 04:33 AM
    Hi all,
    I posted this in the developer board, but it didn't get any views. And since its also regarding CX  switches, maybe someone here can help me.
    I wanted to develop a custom NAE script but I just can not find any documentation for the NAE class. On ASE and Github I can only find example NAE scripts.
    What library do I need to install in my venv to get the NAE class?
    For example:
    What exactly is the Monitor in the NAE class
    What is the list of all Actions (like "ActionSyslog", "ActionCLI", etc.)
    Bjarne
    bkohnke
  • 2.  RE: AOS-CX NAE developer documentation
    Posted May 23, 2022 04:25 AM
    If you have a local Aruba contact, it would be worth to check with him some existing training on NAE.
    There are many examples on youtube ABC channel as well:
    https://www.youtube.com/c/ABCNetworking/search?query=nae
    I pick-up one:
    https://youtu.be/GB0Nb2LQ6Yw?t=256
    Vincent Giles
