Wired Intelligent Edge
  • 1.  NBX R6 CDR
    Posted Feb 10, 2009 10:31 PM
    I have a NBX running R6.0.63 and I can't access the call records, it always give me incorrect password I did changed lots of times, but never get access...
    Anyone can help me out?
    tkz!
  • 2.  RE: NBX R6 CDR
    Posted Feb 11, 2009 10:47 AM
    yes, there is an issue where the "General CAll Data reporting" password must be the same as the administrator password. 3com is aware of the issue and working a fix.
    So, go into your CDR and change the password to match the admin password and you should be all set !!!
    Hope this helps !
  • 3.  RE: NBX R6 CDR
    Posted Jun 15, 2009 09:12 PM
    Don't forget also that the CDR passcode must be a minimum of 8 digits
