Wired Intelligent Edge
  • 1.  NBX V5000 Power Supplies
    Posted Jan 09, 2012 12:18 PM
    My NBX V5000 just died and I believe the power supply unit has gone.  It is the dual power-supply system and I am having trouble sourcing a replacement part.  There are two Power-One MPU150-S256 units on a "sled" (chassis).
    Does anyone know where replacement parts might be available?  Locally if possible, I'm in Massachusetts.
  • 2.  RE: NBX V5000 Power Supplies
    Posted Jan 09, 2012 02:45 PM
    All the places I've called said they would only sell them wholesale (eg 500+ units).
    As long as the power/volt/wattage levels match, any standard pc power supply should work, I believe.
    At least, the system board connector matches a PC power supply so in theory it should work.
    The alternative is to buy a complete V5000, unfortunately.
    Were you running with only a single power supply when it died?
  • 3.  RE: NBX V5000 Power Supplies
    Posted Mar 27, 2012 10:51 AM
    I know where to get them fixed, but you will have to send in the power supply so they can use the connectors/wiring harness. For what it costs you can pick up V5000's on the secondary market cheaper. If you obtain a new unit swap out the hard drive tray and your good to go.  There is http://www.ictcompany.com that I think is really close to you, they are in Shrewsbury, MA.
