Comware
  • 1.  Need help with link aggregation in HP A5500-HI switch
    Posted Jan 09, 2014 02:23 PM
    Hello All,
    I am trying to craete  link aggregation on HP A5500-HI switch and so far I have used the following commands:
    Dynamic link aggregation
    system-view
    interface bridge-aggregation 1
    link-aggregation mode dynamic
    quit
    interface GigabitEthernet 1/0/23
    port link-aggregation group 1
    quit
    interface GigabitEthernet 1/0/24
    quit
    port link-type trunk
    port trunk permit vlan 10
    quit
    Check your link aggregation
    display link-aggregation summary
    display link-aggregation verbose Bridge-Aggregation 1
    All those commands work without any issue however when I do display link-aggregation summary I can only see ONE PORT selected and other for UNSELECTED.
    So when I looked at the logs I found the following error: Member port GigabitEthernet1/0/24 of aggregation group BAGG1 becomes INACTIVE because the port's speed is improper for being attached.
    Does anyone here know what does this mean?
    Thanks in advance
  • 2.  RE: Need help with link aggregation in HP A5500-HI switch
    Posted Jan 09, 2014 02:47 PM
    What do you have connected at the other end?  What version of Comware do you have installed in the switch?
    David
  • 3.  RE: Need help with link aggregation in HP A5500-HI switch
    Posted Jan 09, 2014 03:30 PM
    What is the output if you do the following?
    display this
    display this
    display this
    Also using "link-aggregation mode dynamic" means that you activate LACP (if im not mistaken).
    If you want to setup a link aggregation towards another HP A-series switch using LACP isnt really needed.
  • 4.  RE: Need help with link aggregation in HP A5500-HI switch
    Posted Jan 09, 2014 04:29 PM
    I am connecting to a physical server it is a HP server DL360 (I think). Also how do I enable LACP?
    Furthermore I just noticed this port 23 have speed of Auto [10M] where port 24 Auto [1000M]. Now I am thinking it could be cable as I have forced the NIC on the server to be 1000M Full Duplex. Any Idea?
  • 5.  RE: Need help with link aggregation in HP A5500-HI switch
    Posted Jan 09, 2014 05:45 PM
    I think that IEEE states that for 1Gbit or higher you should use auto/auto (speed=auto, duplex=auto).
    So make sure that both ports are set to the same speed and set the server to use auto/auto in order to get a proper link at 1Gbit/s.
    This should do it for you:
    int range gi 1/0/23 to gi 1/0/24
    speed auto
    duplex auto
    quit
  • 6.  RE: Need help with link aggregation in HP A5500-HI switch
    Posted Jan 10, 2014 08:21 AM
    Yes, you have to enable LACP on the Server as well. Else the Server und Switch will not communicate.
    br
    Manuel
  • 7.  RE: Need help with link aggregation in HP A5500-HI switch
    Posted Jan 11, 2014 01:38 PM
    Here are the outputs:
    [sw1]display link-aggregation summary
    Aggregation Interface Type:
    BAGG -- Bridge-Aggregation, RAGG -- Route-Aggregation
    Aggregation Mode: S -- Static, D -- Dynamic
    Loadsharing Type: Shar -- Loadsharing, NonS -- Non-Loadsharing
    Actor System ID: 0x8000, d07e-2865-3fce
    AGG AGG Partner ID Select Unselect Share
    Interface Mode Ports Ports Type
    BAGG1 D 0x8000, 0000-0000-0000 1 1 Shar
    [sw1]display link-aggregation verbose Bridge-Aggregation 1
    Port Status: S -- Selected, U -- Unselected
    Flags: A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
    D -- Synchronization, E -- Collecting, F -- Distributing,
    G -- Defaulted, H -- Expired
    Aggregation Interface: Bridge-Aggregation1
    Aggregation Mode: Dynamic
    Local:
    Port Status Priority Oper-Key Flag
    GE1/0/23 S 32768 1 {ACDEFG}
    GE1/0/24 U 32768 2 {ACG}
    Remote:
    Actor Partner Priority Oper-Key SystemID Flag
    GE1/0/23 0 32768 0 0x8000, 0000-0000-0000 {DEF}
    GE1/0/24 0 32768 0 0x8000, 0000-0000-0000 {DEF}
    I am not sure why it is only selection one port and not both: btw I have ran following commands:
    speed auto
    duplex auto
    quit
    And Finally the following interface summery :
    [sw1-GigabitEthernet1/0/23]display this
    interface GigabitEthernet1/0/23
    port link-mode bridge
    port trunk permit vlan 1 10
    return
    [sw1-GigabitEthernet1/0/24]display this
    interface GigabitEthernet1/0/24
    return
