Vince,
Thanks for taking my question and excuse me if I need to do a better job at providing more information. I'm new to switches and even newer to the forums. We had a network guy for our company but he is no longer with us. I'm just attempting to fix this issue after the lightening strike/power surge took down every piece of equipment on our network (just the networking equipment, mind you). Regardless, I know how to get into a router and get all the information from there. I know how to get into the ProCurve switch, but I don't know many commands. Lastly, this is my first time trying to create a vlan (I'm assuming this is what I'm trying to do). The way our network is set up, there is a router (port 24), 2 VoIP phones (port 25), the ISP router (port 26) and a copier (port 8) going into those ports in the HP ProCurve Switch. I've got the IPs for each of these devices.
To answer your questions:
(1) The old switch I replaced was the HP ProCurve 2620-24 J9623A
(2) Unfortunately, I do not have a saved config. However, I think I have all the information I may need to reconfigure it.
(3) I have two phones set up on it. They are NEC DSX VoIP phones. Each phone uses about 90kb.
(4) After I found the command(s), I saw this info:
a) Maximum Power: 406w; Power in Use: 0 w +/- 6w; Operational Status: On; Usage Threshold (%): 80
b) IP Config [DHCP/Bootp]: DHCP/Bootp; IP Address: 192.168.1.101; Subnet mask: 255.255.255.0
I hope this answers your question. I work for a small non-profit so anything I can do that you can help me with would be an enormous help. Again, I'm just trying to get our phones (and a few other pieces of equipment attached to the switch) working again.
Thank you again.
