Network Management
NETCONF Switch Hewlett Packard Enterprise 1950 (JG963A)
  • 1.  NETCONF Switch Hewlett Packard Enterprise 1950 (JG963A)
    Posted Jul 19, 2022 09:14 AM
    I was wondering if somebody could help me with this issue, I got a HPE 1950 48G 2SFP+ 2XGT PoE+ Switch (JG963A) I was forced to change the password of my admin users because it was too weak, but after I changed the password when I try to manage the device I can´t make any changes, all I got is a blue screen that only allows me to change the password, but when I try to change the password I get this message ¨Operation denied. You do not have sufficient rights to perform the operation or the system is locked by NETCONF¨
    Look these images:
    Image 1
    Image 2
    I would like to find a solution without make a factory reset, because I do not have a backup from the running configuration.
  • 2.  RE: NETCONF Switch Hewlett Packard Enterprise 1950 (JG963A)
    Posted Oct 27, 2023 04:10 PM
    Boa Tarde, também estamos com o mesmo problema.
    Você conseguiu solucionar seu problema?
    Good afternoon, we are also having the same problem.
    Did you manage to solve your problem?
