Wired Intelligent Edge
  • 1.  Netedit 2.0.5 + 10.05.0001: unreachable
    Posted Jul 16, 2020 01:58 PM
    Hi there,
    Since I upgraded from 10.04.0042 to 10.05.0001, my CX switches show as "unreachable".
    I can "curl" the switches from the Netedit CLI and know the server can access the API. Also, commands work (ex.: reboot), and NetEdit can detect the switches versions and model.
    Yet, they show as unreachable. Anyone having the same problem?
  • 2.  RE: Netedit 2.0.5 + 10.05.0001: unreachable
    Posted Jul 20, 2020 05:50 AM
    Problem happens when UBT is configured, and no Mobility Controller cluster is present.
    Switch answers with cluster_name empty ("clustername":""), and Netedit throws an exception, and marks the switch as unreachable.
  • 3.  RE: Netedit 2.0.5 + 10.05.0001: unreachable
    Posted Jul 20, 2020 07:29 AM
    reported to TAC ?
  • 4.  RE: Netedit 2.0.5 + 10.05.0001: unreachable
    Posted Jul 21, 2020 07:55 AM
    Netedit 2.0.6 does not fix this.
  • 5.  RE: Netedit 2.0.5 + 10.05.0001: unreachable
    Posted Aug 04, 2020 04:32 AM
    Bug is identified and supposed to be fixed in next maintenance release 2.0.7.
  • 6.  RE: Netedit 2.0.5 + 10.05.0001: unreachable
    Posted Aug 10, 2020 09:37 PM
    Do you happen to know the ETA for 2.0.7?  I seem to be hitting this bug in 2.0.6
  • 7.  RE: Netedit 2.0.5 + 10.05.0001: unreachable
    Posted Aug 11, 2020 04:55 AM
    This is subject to change and we usually do not commit any date in such forum. Now, this might probably be around early/mid September if not earlier.
  • 8.  RE: Netedit 2.0.5 + 10.05.0001: unreachable
    Posted Aug 27, 2020 07:45 AM
    I guess 2.0.7 didn't make it to market.
    On the asp portal netedit 2.0.8 is available for download since Aug 24, 2020.
    For me it's an improvement over 2.0.5. I had the same issue with a switch being unreachable. With the installation to 2.0.8 it immediately changed to OK
