Network Management
  • 1.  Netedit
    Posted May 23, 2021 10:21 AM
    Hello all
    I have questions about netedit , if it's compatible with other vendors ?(switches, Access points, etc..), and if its can I monitoring and configuring the devices like Aruba CX-Switch or not?
    and if it's not compatible with 3rd party, should use an airwave? as customers want network tool to support SDN Features Like netedit but I think airwave didn't support that yet. so any advice about netedit.
    thank you so much
    Amr Ragab
  • 2.  RE: Netedit
    Posted May 23, 2021 02:56 PM
    Edited by mkk May 23, 2021 03:00 PM
    https://www.arubanetworks.com/assets/ds/DS_NetEdit.pdf
    The following switches running the AOS-CX operating system
    are supported:
    • Aruba CX 6000 Switch Series (6100 isn't support far as i known).
    • Aruba CX 8000 Switch Series
    See also de release notes with a list of supported devices:
    https://www.arubanetworks.com/techdocs/AOS-CX/NetEdit/RNs/5200-7591.pdf
    Marcel Koedijk | MVP Guru 2021 | ACMP | ACCP | ACDA | Ekahau ECSE | Not an HPE Employee | Opionions are my own
