Comware
Network simulator for aruba or proliant switches devices
  • 1.  Network simulator for aruba or proliant switches devices
    Posted Jul 01, 2019 11:53 AM
    Hello Everyone
    I am working in a company which working with HP switches, Aruba and Proliant, but I only remember the Cisco commands.
    I have installed some networks simulators but the commands are very differents that Aruba commads.
    Do you know if there is any network simulator where I can working in an enviroment with Aruba or Proliant switches??
    Thakn you a lot
    Best regards
    David
    #networksimulator
    #Aruba
    #ProLiant
  • 2.  RE: Network simulator for aruba or proliant switches devices
    Posted Jul 02, 2019 05:29 PM
    Cheers, short answer: there isn't.
    Long answer: there isn't a network simulator for HP ProVision NOS (used on most of HP ProCurve switch series) or for Aruba ArubaOS-Switch NOS (based on HP ProVision)...but there are some official well done guides used to learn corrispondence between some Cisco, Comware and ArubaOS-Switch (ProVision) commands...so if you're comfortable with Cisco you will be able to find some like-for-like commands to use into HP/HPE/Aruba environments.
    Forget about ProLiant, that's the product line name of some HP/HPE Servers, no reference with Networking.
