Wired Intelligent Edge
  • 1.  New! HPE Aruba Networking CX 5420 Chassis Switch
    Posted Oct 03, 2024 09:23 PM
    HPE Aruba Networking has announced the new chassis switch - the CX 5420! This is my summary of the CX 5420 presentation I delivered to the last few Airheads Partner sessions in New Zealand and Australia.
    This is a completely new model, following in the footsteps of the long running zl chassis series like the AOSS 5400R. It boasts an updated ASIC, running AOS-CX, with the same 6-bay form factor that uses the highly flexible 24-port based modules. Multiple modules will be available for maximum flexibility in port configuration. With First Customer Ship in December, schools in the Southern Hemisphere might be able to start deploying during the long summer holidays.
    CX 5420 Switch Chassis Overview
    The HPE Aruba Networking CX 5420 Switch Series is a modern, flexible and intelligent modular switch chassis ideal for access, small core and aggregation deployments. Created for game changing operational efficiency with built-in MACsec hardware capability, analytics and automation, the CX 5420 switch chassis provides an enterprise-class access layer solution that's easy-to-deploy, simple, secure and resilient.
    Built from the ground up with a combination of cutting‑edge hardware, software and analytics and automation tools, the CX 5420 switch chassis is a part of the HPE Aruba Networking CX switching portfolio, designed for today's enterprise small and medium campus, branch enterprise networks. By combining a modern, fully programmable OS with the HPE Aruba Networking Network Analytics Engine, the CX 5420 switch chassis switches provide industry leading monitoring and troubleshooting capabilities across the network.
    The first CX 5420 shipped to Australia:
    The CX 5420 chassis switch has All the important features and capabilities of the AOSS 5400R chassis switches, along with the cloud-native CX operating system.
    • Single operating system simplicity. The CX 5420 switch chassis is based on the HPE Aruba Networking CX Operating System (AOS-CX), a modern, database driven operating system that automates and simplifies many critical and complex network tasks.
    • VSX Stacking (2 units). Highly available performance with VSX Live Upgrade, enabling non-disruptive fast upgrades.
    • Robust security and deeper visibility with dynamic segmentation and role-to-role security enforcement, and MACsec.
    • Multiple port types including 25Gb, SmartRate (up to SR10), and POE up to Class 8 (90W)
    CX 5420 Modules
    TAA modules are also available.
    Switch Features
    • Same popular 6-slot enclosure form factor & 24port bays as 5406R
      • Height <= 4U, Depth <= 17.75in / 45cm
    • 2 x MM slots
      • Dual redundant management modules
      • AMD Ryzen x86 CPU, 4 cores, 8 vCPUs
      • MM is half-width and front access
    • 6 x Line-Card slots
      • LC is half-width and front access
      • Max 144 ports. All ports are MACsec capable.
      • PHY only. No forwarding ASIC on LC.
    • 4 x PSU slots
      • located at the rear
      • 1 PSU SKU type, 1600W (hi-line) / 1000W (lo-line)
      • Estimated Maximum available power: ~6300W
      • 144 ports @30W PoE with N+1 Redundancy
      • 96 ports @60W PoE without redundancy
    • 1 x Fan tray
      • single fan tray comprising 4 fans
      • Field-replaceable and hot-swappable fan tray
    Network Management
    All the management flexibility you expect, including support for New Central.
    IRIS
    Expect to see the CX 5420 included in IRIS soon.
    Early Announcement
    This announcement is ahead of the official GA date of 4-Nov. Some materials, documents and processes will be coming later. Key dates in the CX 5420 timeline (remember that APJ is a day ahead of the US):
    • 18-Sep – Announcement
    • 23-Sep – Quotability by SKU
    • 4-Nov – Official General Availability date
      • Orderability and full visibility to all tools
      • Config tools and OCA
      • HPE Quickspecs, etc
    • December
      • First Customer Ship (FCS)
      • Documentation and Release Notes
    FAQ
    Q: Can I reuse zl modules?
    A: The new CX 5420 does look very similar to the AOSS 5406R, but the modules are not compatible. The CX 5420 has new management modules and line cards, and new PSUs and fan-tray.
    Q: Can I reuse existing transceivers?
    A: Yes, older transceivers should be reusable. However, only the more recent versions have been fully tested. It may be worth upgrading to higher speed transceivers anyway (eg 1 to 10Gb or 10Gb to 25Gb), or testing older transceivers for possible transmission/reception degradation.
    Q: Is there a 12-bay model?
    A: No, the 6 bay model shown is the only variant. For larger port counts, a pair could be stacked with VSX, or consider moving up to the larger CX 6400 10 bay chassis.
    Q: Will bundles be sold?
    A: There will be a bundle with chassis, management module, fan-tray and accessories, but no bundles with preconfigured IO modules. Each customer can build the exact configuration required.
    Q: Is the AOSS 5400R End of Sale?
    A: No, the AOSS 5400R series is still available. HPE Aruba Networking always aim to provide at least 6 months notification before end of sale.
    References and Links
    Richard Litchfield
    Airheads MVP 2020, 2021, 2022
  • 2.  RE: New! HPE Aruba Networking CX 5420 Chassis Switch
    Posted 17 days ago
    This is great news!  In our environment over the years we've used the 5400R zl2, 8200zl, and the 5300zl, all great performing switches!  It would be great if a larger chassis was available.  Say a 12 slot.  This would allow for the greatest flexibility for environments that need density.  But not at the CX6400 level.  Please consider this option.
  • 3.  RE: New! HPE Aruba Networking CX 5420 Chassis Switch
    Posted 17 days ago
    Edited by Richard Litchfield 17 days ago
    Yes, it is a great evolution of a unique form factor!
    Unfortunately the volume of 12 bay chassis sold compared with the smaller 6 bay chassis makes justifying the larger 12 bay model difficult. Especially where there are 2 alternatives already:
    1. VSX stack of CX5420 will enable almost the same port count (272 x 1Gb POE+/Class4 RJ45 when 2 x 25Gb modules are used in each chassis)
    2. Single CX6400 10 bay (480 x 1Gb POE+/Class4 RJ45)
    Richard Litchfield
  • 4.  RE: New! HPE Aruba Networking CX 5420 Chassis Switch
    Posted 17 days ago
    Hi
    The 5420 is a nice switch.
    But who came up with the idea of ​​"calling" the first module with network ports Slot 3 and the two MGMT modules Slot 1 and Slot 2?
    On the 5400R the first slot is "A", why don't you start with "1" there on the 5420?
    sh int bri
    1/3/1 1 access 1GbT yes down Waiting for link -- --
    1/3/2 1 access 1GbT yes down Waiting for link -- --
    1/3/3 1 access 1GbT yes down Waiting for link -- --
    1/3/4 1 access 1GbT yes down Waiting for link -- --
  • 5.  RE: New! HPE Aruba Networking CX 5420 Chassis Switch
    Posted 15 days ago
    Hi, my contribution: from the user's point of view... I think that, from our side, this is the price we pay in "approaching" (and, considering the vendor's point of view on the other side, also "in the way it was presented") this particular product thinking (fueled by our past consolidated experiences) to expect [*] that the newer Switch behaves totally like the older one (so, for example, Slot 1 should represent Module 1 and not Management Module 1), as we were used to do or more or less like this.
    For example, if you approach the Aruba CX 6400 you will not expect anything special because there is no previous similar switch to make a comparison with (the chassis is new, the software is new); if you instead approach the Aruba CX 5420 (as you did) you have the right to expect to recognize something also in its internal logic (since they are the same externally), because there is a similar previous switch, the one the vendor suggests to migrate from, to make a comparison.
    The above to say that...IMHO...what you found is a valid and shareable opinion.
    A good question.
    I feel like I already know the probable answer: it is due to the way the AOS-CX software is designed (relative to the hardware). Simple.
    Nothing against this or that, just thoughts.
    [*] Why? because one is unwittingly led by the vendor to believe that the new Aruba CX 5420 is somehow "the same" as the old Aruba 5406R zl2 with the consequence that, precisely for this reason, it will facilitate both a physical and conceptual migration (because the vendor has wisely chosen an identical "chassis form factor" and an almost identical "chassis design" -> but if the exterior can be considered almost the same in a comparison between Aruba CX 5420 and Aruba 5406R zl2, the interior and the software running on it are not, hence the differences).
  • 6.  RE: New! HPE Aruba Networking CX 5420 Chassis Switch
    Posted 13 days ago
    Hi Davide
    everything said, :-)
    Tom
  • 7.  RE: New! HPE Aruba Networking CX 5420 Chassis Switch
    Posted 12 days ago
    Hi all, There is not one choice satisfying all expectations in that matter.
    The principle was to be consistent with existing CX 6400 series.
