The main difference is that V10 is cloud based management only and V8 has local/on prem/controller/cloud management options available.
For other differences just search community or hpe.com networking page.
You have many youtube videos available on Aruba Broadcasting Channel going in depth on this topic.
Original Message:
Sent: Sep 18, 2024 10:16 PM
Subject: Newly deployed AP505 show config unsynchronized
i managed to get Aruba support to help with the issue.
by the way, what is the difference between firmware version 8.10.xx and version 10.xx ?
what new features are available in 10.xx
Original Message:
Sent: Sep 18, 2024 02:42 PM
Well.
will stick on the latest recommend 10.4.1.3_90100
the only thing now is we will maintain some AP 505 on 10.6.0.2 , since its impossible to revert them to 10.4.1.3..
gives an error, but ok
Original Message:
Sent: Sep 18, 2024 12:20 PM
Up to you and whether or not everything is working fine for you. 10.7 is an SSR.
Carson Hulcher, ACEX#110
Original Message:
Sent: Sep 18, 2024 11:59 AM
I have AP's on 10.6.0.3
Should I leave the gW on this 10.4.1.3? or push all GW and APś to 10.7? is 10.7 LSR?
Original Message:
Sent: Sep 18, 2024 11:22 AM
AOS 10 supports differing versions of software between gateways and APs, as long as all devices are within an LSR to LSR. Which means that right now AOS 10.4 and 10.7 are supported options.
To see the "recommended version" column on gateways, go to Firmware and show the gateways, or in the case of clusters you'll need to drill into the cluster.
The recommendation, outside of Central's "recommended version" which is based on an algorithm, is to run the same version on AP and gateway when possible.
Original Message:
Sent: Sep 18, 2024 11:01 AM
Hi.
ok. makes sense
But were can we find the recommended for gateways in Central?
I feel that is more accurate to have GW and AP's in the same version , but i do not see were to find the recommended
Regards
Original Message:
Sent: Sep 18, 2024 10:45 AM
10.6.0.3 is available, that would be preferred over 10.6.0.2 if upgrading. But 10.7 has been released which means that the 10.6 train will be EOL very quickly.
Original Message:
Sent: Sep 18, 2024 10:39 AM
Hi all
Seems that version 10.6.0.1.89990 on AP 505 puts the radio down
Upgrading to version 10.6.0.2 problem goes away.
yesterday 10.6.0.1 was the recommend version, today is 10.6.0.2
Regards
Original Message:
Sent: Sep 18, 2024 10:14 AM
Here you can find errors occurred during the deployment of the change. Usually you'll find 3 dots at the event with configuration change that is applied or failed.
Best, Gorazd
Gorazd Kikelj
MVP Guru 2024
Original Message:
Sent: Sep 18, 2024 08:41 AM
Hi
Do you say Configuration audit?
Regards
Original Message:
Sent: Sep 18, 2024 07:21 AM
Check in audit log for the reason.
Best, Gorazd
Gorazd Kikelj
MVP Guru 2024
Original Message:
Sent: Sep 17, 2024 06:20 PM
Hi Also have similar problem
AP 505 on the same group of the other 505
Config says insyncronized and radios are disable
Original Message:
Sent: Sep 05, 2024 08:02 PM
you can also check the the configuration audit for clues.
Original Message:
Sent: Sep 05, 2024 10:51 AM
Various reasons, usually just requires forcing the sync to fix.
Original Message:
Sent: Sep 05, 2024 09:33 AM
recently we deployed a number of new AP505 in Aruba Central.
then we discovered that a few of them is showing config unsynchronized.
what could be the reason. its online n there are clients connecting to them.
