Comware
  • 1.  NIC team configured problem
    Posted Apr 11, 2006 02:03 AM
    Hi All,
    I make a NIC team configured in Proliant 380G3. It's successful. May I connect the two ethernet cable to different ethernet switch? Because I have the cisco switch redundancy architectrue.
    see attached file.
    Thanks!
  • 2.  RE: NIC team configured problem
    Posted Apr 11, 2006 03:14 AM
    This is a common question. Yes you can, but this is depends on teaming mode.
    Look this post for more details: http://forums1.itrc.hp.com/service/forums/questionanswer.do?threadId=1016319
  • 3.  RE: NIC team configured problem
    Posted Apr 12, 2006 06:57 AM
    Basic Summary:
    These team types can have teamed adapters connected to more than one switch:
    - Automatic
    - NFT
    - TLB
    - Dual Channel
    - 802.3ad dynamic Dual Channel
    These team types require the teamed adapters to be connect to the same switch:
    - SLB
    - 802.3ad
    I've provided this information and a lot more in a whitepaper I wrote about NIC Teaming. You can find it here:
    ftp://ftp.compaq.com/pub/products/servers/networking/TeamingWP.pdf
    (Look at figure 3-4. Anything labeled "Switch fault tolerance" can have Teamed adapters connected to more than one switch).
    Remember, all ports belonging to the same team MUST be connected to switch ports that are on the same broadcast domain/subnet. This applies to ALL team types.
    Best Regards,
    -sean
