It all depends about which "teaming" method the OS is going to be configured with...as example: if, Server side, the host's OS is going to be configured with IEEE 802.3ad (LACP) on its four NIC Ports (that's an example) a corresponding configuration on peer (physical/virtual) Switch is required too (creating a LAG Link Aggregation Group, assigning member links to that LAG, etc.)...so, from a pure Networking standpoint, not only knowing what type of "team" the Server host will be configured with but also knowing where the "team" member links are going to terminate is quite important too.
