Hello All
I am currently looking to improve network performance to our file server which i just bought an Intel Quad NIC, my idea being that i can use some kinda of load balancing. the file server is running 2003, sharing files to around 800 clients.
I was wondering which teaming option is the best to use to improve network performance to the server with our switch which is a procurve 4108gl and 4 gigabit ports on the switch.
If i use 4 gigabit ports to the server using LACP is there any configuration needed to be performed on the switch in its default state.
my last question is how much should the network performace to the server be improved?
thank you for any help in advanced
James
