Do you think you could find out what the HP recommended NIC Adapter Team settings are? I have read a bunch of white papers and they don’t really specify what the settings should be, only what each setting does.
I normally leave them set to the default of Automatic (which is recommended). This setting is Transmit Load Balancing with Fault Tolerance.
We have 2 HP Procurve 4208’s trunked together. I would like to find some advice on what adapter settings go best with these Procurve switches.
thanks for my customer!
dan
