SD-WAN
  • 1.  No GUI once logged in - how do I troubleshoot
    Posted Nov 21, 2014 09:03 AM
    I have the controller up and running, I have checked the sdnc service status
    also have this info
    $ netstat -na | grep 35357
    tcp        0      0 0.0.0.0:35357           0.0.0.0:*               LISTEN
    $ netstat -na | grep 8443
    tcp6       0      0 :::8443                 :::*                    LISTEN
    I can get to the rsdoc on  https://<hostIP>:8443/api/
    I am runnging Java 7u80
    Tried in latest Chrome and Firefox
    Max and Windows,
    I think this is something wrong with the way have built it although followed the guide a few times.
  • 2.  RE: No GUI once logged in - how do I troubleshoot
    Posted Nov 21, 2014 10:26 AM
    I suspect you might have skipped the step in section 2.2.3 of the guide you're following:
    1. Edit the /etc/keystone/keystone.conf file with the following line to set UUID as the
    provider type:
    provider=keystone.token.providers.uuid.Provider
    For example, in the Icehouse version of Keystone, you would insert the above command in
    the [token] section of the file, as shown in the boldface entry, below:
    [token]
    # Options defined in keystone
    # External auth mechanisms that should add bind information to
    # token e.g. kerberos, x509. (list value)
    #bind=
    # Enforcement policy on tokens presented to keystone with bind
    # information. One of disabled, permissive, strict, required
    # or a specifically required bind mode e.g. kerberos or x509
    # to require binding to that authentication. (string value)
    #enforce_token_bind=permissive
    # Amount of time a token should remain valid (in seconds).
    # (integer value)
    #expiration=3600
    # Controls the token construction, validation, and revocation
    # operations. Core providers are
    # "keystone.token.providers.[pki|uuid].Provider". (string
    # value)
    # Keystone Token persistence backend driver. (string value)
    #driver=keystone.token.backends.sql.Token
    # Toggle for token system cacheing. This has no effect unless
    # global caching is enabled. (boolean value)
    #caching=true
    1 Adding this line sets
    the UUID provider
    type.
    2. Restart the Keystone server.
    Please let me know if the above solves your problem,
    Antonio
    SDN CoE Team
  • 3.  RE: No GUI once logged in - how do I troubleshoot
    Posted Nov 24, 2014 10:46 AM
    brill that worked
    i had put the provider line was in the wrong the place :-)
