Network Management
  • 1.  No Inter VLAN Routing
    Posted Mar 26, 2019 05:32 PM
    I can not get inter VLAN routing to work. I currently have my UTM going to my switch. I have added in the networks on my UTM. It still will not work. Please help!
    Attachment(s)
    txt
    PreReset.txt   1 KB 1 version
  • 2.  RE: No Inter VLAN Routing
    Posted Mar 26, 2019 08:40 PM
    Going through the configuration, you don't need LACP trunk group. So remove following command:
    trunk 28 trk1 trunk
    All access ports will be untagged for specific VLANs and all trunk ports will be tagged for desired VLANs.
    I am assuming you have port 28 connected to UTM, so 28 will be tagged for all VLANs.
    Also, sanity check.. ip default-gateway 192.168.120.2 is not required once you have enabled routing and "public" SNMP community to be changed.
  • 3.  RE: No Inter VLAN Routing
    Posted Mar 27, 2019 12:35 PM
    I am currently using port 1 to connect to the UTM. The UTM does not have a fiber port so my plan was to go to UTM via port 1 so it is untagged on VLAN 1 and tagged on all the others. Port 28 was going to be connection to another 2830F. The building has multiple floors and this is the connection for the Core device that would bring the network into it.
    Lionel Fermin
    Thanks for your quick reply by the way!
