Comware
  • 1.  Non-HP x2 / minigbic transceivers are not possible?
    Posted Oct 16, 2009 02:18 AM
    I saw a posted dated back in 2006 about this, I was hoping there are updates / changes? We just purchased a 5410zl setup, with the 4 port x2 10gbe module, and from what I can see none of our existing hardware will work with it. On cisco's you could ignore the messages and still use it (or in this case we would use cisco gbics on hp). From what I can see all of the HP stuff is crazy over priced (far more than what we were paying for cisco x2 transceivers). Payig $2,500 for a single x2 transceiver seems ridiculous.
    Anyhow, I just wanted to see if there are any options, if not I guess I will need to dump the idea of using HP's within our network. Thanks for your time!
  • 2.  RE: Non-HP x2 / minigbic transceivers are not possible?
    Posted Oct 16, 2009 09:12 AM
    I don't believe there's a way around the third party GBIC/transceiver issue (not if you want to be running the current firmware anyway).
    What type of X2 transceivers are you using?
  • 3.  RE: Non-HP x2 / minigbic transceivers are not possible?
    Posted Oct 16, 2009 03:05 PM
    X2 transceivers from HP are indeed very expensive, and currently there is no way to use non genuine ones.
    You migh however consider using SFP+ modules with much lower prices. For example SRP price for J9150A (10-GbE SR) is 1239,00E. It is also worth to notice that HP offers *very* nice discounts, so the final price should be much lower.
  • 4.  RE: Non-HP x2 / minigbic transceivers are not possible?
    Posted May 18, 2010 10:19 AM
    It is possible. What kind of x2 were you looking to purchase?
  • 5.  RE: Non-HP x2 / minigbic transceivers are not possible?
    Posted Jul 29, 2010 04:40 PM
    Does anyone have any information on if you can force the switch to recognize the non-hp gbic? I have a handful of AO mini-gbics and I would hate to go out and buy all new gbics.
    Mike.
  • 6.  RE: Non-HP x2 / minigbic transceivers are not possible?
    Posted Jul 30, 2010 10:18 AM
    For what it's worth (and YMMV), I've been having no problems using non-hp SFP mini gbics with current firmware. I always just look for the ones that have an 'OEM compatible guarantee' such as Axiom J4858C-ax or even super cheap Add-On Computer J4859C-AO.
    I'm running current FW on a 6200yl-24 and 3500yl-24G and both of the mentioned gbics are performing normally on my test bench.
