Wired Intelligent Edge
  • 1.  Not able to backup config via TFTP - output gives Command incomplete
    Posted 24 days ago
    Hello
    I am trying to backup the startup config from the CLI to my TFTP server. Using Solar Winds.
    Should be straight forward, and I am following the guide on HP/ Aruba own site here:
    https://arubanetworking.hpe.com/techdocs/AOS-CX/10.13/HTML/fundamentals_8400/Content/Chp_Cfg_FW_mgt/FW_mgt_cmds/cop-rem-url.htm
    I have tried the sommands like this
    SwBrsl021# copy startup-config tftp://192.168.10.22/file1
    % Command incomplete.
    SwBrsl021# copy startup-config tftp://192.168.10.22/file.txt
    SwBrsl021# copy startup-config tftp://192.168.10.22:69/file.txt
    SwBrsl021# copy startup-config tftp://192.168.10.22:69;blocksize=1462/file2.txt
    SwBrsl021#
    What am I doing wrong, please help.
  • 2.  RE: Not able to backup config via TFTP - output gives Command incomplete
    Posted 24 days ago
    Hi
    Use the question mark to see what is missing. If I remember correctly, you should mention the format of the config (json, cli).
  • 3.  RE: Not able to backup config via TFTP - output gives Command incomplete
    Posted 24 days ago
    Hi Thomas
    Awesome thank you, that worked.
    I was just missing the "cli" at the end. My command ended up looking like this.
    copy startup-config tftp://192.168.10.22:69;blocksize=1462/file2.json cli
  • 4.  RE: Not able to backup config via TFTP - output gives Command incomplete
    Posted 24 days ago
    Hi Jakob
    I'm glad that it worked. Have fun.
    Regards, Thomas
