Cloud Managed Networks
  • 1.  Not all wired clients are displaying in central.
    Posted May 03, 2022 01:23 PM
    We have two Aruba 8320's in a vsx stack with 9 MC lags configured.  5 of those lags are connected to a Hyper-Cluster (5 Hyper-V hosts) with roughly 70 VM's running on them.
    When i view my switches on central, I see 4 clients connected to the primary switch and 0 connected to the secondary.  I do have a case created with Aruba but I figured I would try here and see if anyone has seen this before?
    This stack is in production and seems to be fine.  I just don't know what I am missing here.
    Brian Moebius
  • 2.  RE: Not all wired clients are displaying in central.
    Posted May 06, 2022 07:47 PM
    did you sort this out? i believe you need to enable LLDP for Physical Interfaces properties, something like "Microsoft LLDP Protocol Driver" and "Hyper-V Extensible Virtual Switch", check the MS doco
  • 3.  RE: Not all wired clients are displaying in central.
    Posted Feb 17, 2023 08:13 AM
    Time flies... I haven't had much time to get back to this over the past few months.  Now that we have finally finished a few projects I can get back to this.
    LLDP is enabled on our servers and I do see the MAC-Addresses listed in the MAC-Address table on the switch itself.  When I run a show arp command I do not see them.  I wonder if there is a configuration I need to set on the Hyper-V switch to pass the data.
