Not enough flash space
This thread has been viewed 108 times
  • 1.  Not enough flash space
    Posted Mar 15, 2013 01:37 PM
    trying to upgrade 620 controller and i get the error "Not enough flash space".  cleaned everything out of filesystem that is not needed and rebooted still not enough space.
    (controller_140) #dir
    -rw-r--r--    1 root     root        22111 Mar 15 09:15 20130313-config
    -rw-r--r--    1 root     root        22266 Mar 15 10:13 default.cfg
    drwx------    2 root     root            0 Mar 15 09:36 tpm
    (controller_140) #show memory
    Memory (Kb): total: 387684, used: 294104, free: 93580
    (controller_140) #show storage
    Filesystem                Size      Used Available Use% Mounted on
    /dev/mtdblock11         156.0M    118.7M     37.3M  76% /flash
    none                    300.0M      2.2M    297.8M   1% /tmp
    /dev/mtdblock9           50.0M     24.8M     25.3M  50% /mnt/img0
    /dev/mtdblock10          50.0M     24.5M     25.5M  49% /mnt/img1
  • 2.  RE: Not enough flash space
    Posted Mar 15, 2013 01:40 PM
    type "tar crash" to see if there is a crash.tar file.  If there is, delete it, reboot and try again.
  • 3.  RE: Not enough flash space
    Posted Mar 15, 2013 02:03 PM
    (controller_140) #tar crash
    No crashes found on this machine.
  • 4.  RE: Not enough flash space
    Posted Mar 15, 2013 04:44 PM
    Please open a support case.  TAC could see if there are any "hidden" files that can be removed...
  • 5.  RE: Not enough flash space
    Posted Mar 15, 2013 06:42 PM
    I had the same problem and got back enough space after deleting all but two saved configs.
  • 6.  RE: Not enough flash space
    Posted Mar 22, 2013 02:30 PM
    Upgraded the Controller using the CLI instead of GUI and it worked fine.
    (controller_140) #copy tftp: 172.20.21.145 ArubaOS_6xx_6.1.3.7_37112 system: partition 1
    Copying file:..........................
    Saving file to flash:
    (controller_140) #
    (controller_140) #show image version
    Partition               : 0:0 (/dev/mtdblock9)
    Software Version        : ArubaOS 6.1.3.5 (Digitally Signed - Production Build)
    Build number            : 35523
    Label                   : 35523
    Built on                : Fri Sep 28 07:46:05 PDT 2012
    Partition               : 0:1 (/dev/mtdblock10) **Default boot**
    Software Version        : ArubaOS 6.1.3.7 (Digitally Signed - Production Build)
    Build number            : 37112
    Label                   : 37112
    Built on                : Fri Feb 8 18:08:20 PST 2013
    (controller_140) #
    (controller_140) #write memory
    Saving Configuration...
    Configuration Saved.
    (controller_140) #
  • 7.  RE: Not enough flash space
    Posted Jul 18, 2013 07:41 AM
    it worked with me just one time, when i tried again i got the free space error message!!!, any help please??!!!1
  • 8.  RE: Not enough flash space
    Posted Jul 18, 2013 07:43 AM
    Try from the commandline or contact tac to see if there are any hidden files.
  • 9.  RE: Not enough flash space
    Posted Jul 18, 2013 08:07 AM
    i did from CLI , no result, i am waiting reply from the TAC team
  • 10.  RE: Not enough flash space
    Posted Jan 29, 2014 08:53 PM
    ran into the same problem trying to upgrade my controller to 6.3 only  this time the GUI and the CLI did not work.  I had to boot off the inactive partition (1) then upgrade partition 0 with the CLI and it worked.
  • 11.  RE: Not enough flash space
    Posted Sep 22, 2016 07:59 AM
    Reboot the controller with the secondary boot partition is the best solution to upgrade a controller without free space in the flash.
    After the rleoad with the second partition I can upgrade the ARUBA 650 controller with a new firmware:
    (Aruba650) #boot system partition 1
    (Aruba650) #reload
    (Aruba650) #copy tftp: 10.10.10.10 ArubaOS_6xx_6.4.4.9_55980 system: partition 0
  • 12.  RE: Not enough flash space
    Posted Jun 20, 2014 04:54 PM
    Will the controller automatically try to boot from the newer OS - and revert to the backup OS - when it is rebooted?  Or do I have to set the boot partition to the newer image?
  • 13.  RE: Not enough flash space
    Posted Jun 20, 2014 05:02 PM
    check and see which partition is being used to boot. with the command show image version. Set the system to boot from a partition with the command boot system partition 0 OR boot system partition 1
    Partition               : 0:0 (/dev/mtdblock9) **Default boot**
    Software Version        : ArubaOS 6.3.1.2 (Digitally Signed - Production Build)
    Build number            : 41362
    Label                   : 41362
    Built on                : Wed Dec 18 17:35:16 PST 2013
    Label                   : 37112
    (controller_140) #boot system partition 1
  • 14.  RE: Not enough flash space
    Posted Jun 20, 2014 05:09 PM
    Thank you.  That's what I thought.  It would be nice if the OS could automatically try to boot from the newer OS version first and then fail to the other partition if it can't boot.  this would allow you to force the boot partion with the boot system partition command, or have it boot to the newer OS automatically.
  • 15.  RE: Not enough flash space
    Posted Jun 20, 2014 05:17 PM
    Actually that is what happens. Let me be more clear. When you upgrade a partition to a new version of code that partition gets set as the default boot partition on the next boot.  It does not automatically boot the system b/c that allows you to load the software during production hours and reboot/upgrade the system after hours.  If the system cannot boot off the new code it will reboot into the old partition with the previous version.
  • 16.  RE: Not enough flash space
    Posted Jun 20, 2014 05:27 PM
    Thank you.  That was helpful.  I've been waiting for about 45 minutes for the tftp upload to complete.  I'm still getting the scrolling periods (.........), but I'm beginning to think that this thing is in trouble.
    I had first tried doing this upgrade through the GUI, but that failed.  I got the "not enough space" error, then rebooted and tried again.  I didn't get the error the second time, but something happened and the older image in partition 1 (3.4) got corrupted - I am booted off of partition 0.
